Problem to do backup CCM
Oct 7th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
I am trying to do the backup using the tool BARS and is appear the following message:
"The CCM DB on publisher 10.9.8.81 is not published. Please correct this invalid configuration by properly publishing the CCM DB on publisher before configuring this server as data source server"
I have additional information: The CallManager 4.2.1 is installed in Virtual Machine.
Thank You,
Wilson Santana
basyadav Tue, 10/07/2008 - 05:06
  • Cisco Employee,
Hi Wilson
What is the CM version you are using?
If you are running a cluster, this is definetly an issue with the Database . Please Check by running "DBhelper" on publisher from the bin folder.
- Basant
wilsonsant Tue, 10/07/2008 - 05:13
Hi Basant,
In our Customer we have only CallManager that running version 4.2.1 and according I informed this CCM is installed in the Virtual Machine. I can check the "DBhelper", but, that can be configured?
Best Regards,
Wilson
basyadav Tue, 10/07/2008 - 05:16
  • Cisco Employee,
so is this a single CM 4.2 running on VMWare machine?
wilsonsant Tue, 10/07/2008 - 05:18
Hi Basyday,
The answer is yes, this CCM 4.2 is running on VMWare machine. Is possible to do the Backup?
Thank You,
Wilson
basyadav Tue, 10/07/2008 - 05:37
  • Cisco Employee,
Hi Wilson
I am not sure of its possible to do a backup on VMWare or not however taking a snapshot is I would prefer than running BARS on CM.
- Basant
mikram Tue, 10/07/2008 - 05:38
  • Bronze, 100 points or more
Hi Wilson,
I am also running CUCM on vmware and do backup on network drive which is another vm. Create a share folder on destination machine with user login name and password. It should work.
Good Luck.
Ikram
wilsonsant Tue, 10/07/2008 - 05:44
Hi Ikram,
Did you see the message error that is occuring when we tring to do the Backup posted in the start this conversation?
Thank You,
Wilson Santana
