MARS-20, upgrade from 4.3.6 to 6.0.1.
Same appliance upgrade path.
When I try to import the config from a 4.3.6 export I get this message:
pnimp> import config 192.168.0.21:/archive/mars_2008-10-07-10-23-33
The most recent configuration archive from 4.3.1 release or later found on the archive server was created at 2008-10-07-10-23-33
Export finished successfully!
Any idea?
Thanks.
htarra Mon, 10/13/2008 - 07:12
  • Bronze, 100 points or more
It is difficult to say what could have caused this issue. But I think the issue could be due to ssh and re-image. Can you try to run model/version/pnstatus/hostname. And try to find out the disk space status on your remote file system.
As per the migration guide, you must first export your CS-MARS-100E's 4.3.6 configuration and data, re-image the unit to 6.0.1 and then import the configuration and data.
Migrating Data from Cisco Security MARS 4.x to 6.0.1:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/migration/guide/dmigrate6x.html
rajett Wed, 10/29/2008 - 15:52
  • Cisco Employee,
Check your permissions on the system used to store the data.
Are there any errors listed on that system?
