Cisco 7941 MGCP support
Answered Question
Oct 7th, 2008
Does Cisco 7941 support MGCP protocol. What is the main differens between 7940 and 7941(except the screen resolution).
Correct Answer by testeven about 8 years 3 months ago
Hi!
The 7941 is a 3rd generation phone, some enhancements are:
- backlit phone line buttons (amber, green, red) to indicate line state
- higher resolution grayscale display
- additional fonts that support unicode and double-byte characters
- more intuitive icons
- Enhanced ? Button Help
- Feature Menu Display
- Enhanced Directory Features
For more information you can check th 7941 data sheet:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6513/product_data_sheet0900aecd802ff012.html
Here's a tutorial:
http://www.cisco.com/comm/applications/CCNP/qlm/7941/index.htm
Here you will find Enhancements and some comparisson between the 7940 and the 7941G
http://www.cisco.com/en/US/products/hw/phones/ps379/products_user_guide_list.html
And the 7941 does not support MGCP protocol, only SCCP and SIP
HTH, if it does, please rate! :)
Tere.
Overall Rating: 5 (1 ratings)
Correct Answer
testeven Tue, 10/07/2008 - 09:31
Hi!
Here's a tutorial:
Tere.
