satish_zanjurne Tue, 10/07/2008 - 07:14
I will suggest following
1.Redistribute static into EIGRP on router R5
2.Run eBGP between EIGRP 1 & EIGRP 2 autonomous systems
HTH...rate if helpful..
Giuseppe Larosa Tue, 10/07/2008 - 07:53
Hello Saravana,
you need to provide a return path for packets originated on R5 to have ping tests to be successuful
Note 3:
automatic failover : --> you need a dynamic protocol on the two links.
the best choice is BGP.
R5 needs to redistribute in EIGRP static routes pointing to R6
redistribution of static routes in R3 and R4 just allows them to reach 50.50.50.50 on EIGRP AS 1.
use on R1 and R2 AS 65001
AS 65002 on R3 and R4.
R1:
router bgp 65001
neighbor 172.16.10.2 remote-as 65002
network 20.20.20.0 mask 255.255.255.252
network 30.30.30.0 mask 255.255.255.252
network 50.50.50.50 mask 255.255.255.255
router eigrp 1
red bgp 65001
R2:
router bgp 65001
neighbor 172.16.20.2 remote-as 65002
router eigrp 1
red bgp 65001
R3:
router bgp 65002
neighbor 172.16.10.1 remote-as 65001
network 192.168.10.0 mask 255.255.255.252
network 192.168.20.0 mask 255.255.255.252
network 10.10.10.0 mask 255.255.255.252
network 60.60.60.60 mask 255.255.255.255
router eigrp 2
red bgp 65002
R4)
router bgp 65002
neighbor 172.16.20.1 remote-as 65001
router eigrp 2
red bgp 65002
R5
router eigrp 2
red static
Hope to help
Giuseppe
