In CallManager, is there a way to log calls going through your Inter-Cluster Trunk or Trunk that is using your Gatekeeper? I just want to find out the number of calls or maximum calls at one given time to find out if my VOIP trunk is being over-subscribed. Please let me know, thank you.
This is clearly visible in RTMT and can be monitored realtime.. You can also dump all the logs from RTMT...
The field you will see this under is Trunk Activity
HTH, please rate useful posts..
Chad
