a problem with backup after upgrade from LMS 3.0 to LMS 3.1
Answered Question
Oct 7th, 2008
The customer has a problem with backup. Backup starts, but when it finished the following message is appeared:
Starting database engine rmengEng
[Wed Oct 1 20:56:57 2008] ERROR(969): Fatal error: Database engine 'rmengEng'
could not be started on database 'rmengdb' in Bulk mode..
[Wed Oct 1 20:56:57 2008] Backup failed: 2008/10/01 20:56:57
and the result is: Backup failed.
Can you help me? Thank you.
Correct Answer by Joe Clarke about 8 years 1 day ago
Yes, but you have to open a Service Request with TAC to get it.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 10/07/2008 - 07:25
Please post the list of contents in the NMSROOT/databases/rmeng directory.
Joe Clarke Wed, 10/08/2008 - 07:56
Shutdown Daemon Manager, delete the rmeng.log, then run:
D:\CW2000\objects\db\win32\dbsrv9 -f D:\CW2000\databases\rmeng\rmeng.db
Then restart Daemon Manager. Your backup should work.
ROMAN TOMASEK Fri, 10/10/2008 - 04:18
the customer tried to use your method, but the result is same:-(
He used dbsrv10, because he didn't find dbsrv9 file in the directory win32.
Joe Clarke Fri, 10/10/2008 - 06:56
I had assumed you were doing the backup under LMS 3.0.1. Under LMS 3.1, the command would be dbsrv10. When Daemon Manager is running, does the RMEDbEngine process come up? Please post the output of the pdshow command.
ROMAN TOMASEK Wed, 10/15/2008 - 05:53
I'm sending you the answer from my customer.
Scheduled usign GUI - daily, without generations, 20:45 local time, directory on local disk
Gzipped dbbackup.log has now almost 28 MB, so I do not include it.
Joe Clarke Wed, 10/15/2008 - 20:31
Does the backup work if run manually:
NMSROOT/bin/perl NMSROOT/bin/backup.pl
ROMAN TOMASEK Mon, 10/20/2008 - 00:42
the customer tried manually backup, but the result is same:-( See answer from my customer:
The result is the same - same error message
Joe Clarke Mon, 10/20/2008 - 08:12
What do they get if they run the following command with Daemon Manager running:
D:\CW2000\bin\perl D:\CW2000\objects\db\conf\configureDb.pl action=validate dsn=rmeng
ROMAN TOMASEK Thu, 10/23/2008 - 02:49
I have the requested output. Roman
When I enter the command WITH Daemon Manager stopped, I get output, which is included.
In both cases I omitted part of command - "jsessionid=2EBD87BC3B46D9F333700F4D231BA4E5.SJ5B". I hope it doesn't matter so much
Joe Clarke Thu, 10/23/2008 - 07:52
Your syslog dataspaces are corrupt. There is a utility available from the TAC called DBSpaceReclaimer.class which can be used to drop these dataspaces. The alternative is you will need to either restore a known good LMS backup, or reinitialize your RME database.
Correct Answer
Joe Clarke Fri, 10/24/2008 - 06:07
