ASA5520 stops passing traffic
Oct 7th, 2008
A couple of times now, an ASA5520 - Software Version 7.1(2) stops passing traffic (no changes made to the ASA for weeks). The interfaces are up/up (one is connected to a 3750 (full/1000Mbps) and the other to a LES100 circuit (full/100Mbps) and no errors are on the interfaces. I can ping from the ASA GUI tools option to remote devices, but cannot ping or telnet through the ASA (normally I can). There are duplicate SYN packet messages which implies to me that the packets are being re-transmitted with no response (indicates a physical connectivity issue - powered off the LES100 circuit but still a problem). A power off/on fixes the issue, but a reload doesn't.
Can someone give me some pointers where I can start to look the next time this occurs?
mchin345 Mon, 10/13/2008 - 11:58
  • Silver, 250 points or more
Traffic through the ASA also stops a passing.
The problem is resolved after rebooting the ASA.
If this is the case then you are hitting this bug CSCse08133
The only solution is to upgrade your IOS
mbookham Tue, 10/14/2008 - 12:17
Thanks for taking the time to reply, however that BUG ID is not the issue:
CSCse08133 Bug Details
SSH and other to the box traffic denied because of no connection
Symptom:
After a period of time, administrators are unable to SSH, or ping the interface
of the security appliance.
Conditions:
SSH or ping were successfully working before, but stopped. Checking the syslogs
indicates that the to-the-box traffic is being denied as through-the-box traffic.
Workaround:
Re-enter the IP address on the interface.
My issue is:
I can still access the box ok, but no traffic is passing through it. I can ping devices on both interfaces from the ASA itself.
netadminquid Fri, 11/21/2008 - 02:05
I have the same identical problem, I'd like to know if you have resolved the problem.
Thank you, and sorry if I could help you.
