ACE Appliance Redundancy
Oct 7th, 2008
  • Gold, 750 points or more
I've been testing redundancy of a pair of ACE 4710 Appliances (A3(1) software) in our lab and run into a peculiarity in the FT configuration. I configure the FT exactly as in the configuration guide and it works perfectly as long as I use a cross-over cable between the FT interfaces. This is the relevant config (other ACE same apart from IP's reversed).
interface gigabitEthernet 1/4
ft-port vlan 10
ft interface vlan 10
peer ip address 192.168.1.2 255.255.255.0
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 10
ft-interface vlan 10
query-interface vlan 90
ft group 1
peer 1
associate-context Admin
inservice
As I said - works great with a crossover cable. However, the appliances will be far enough apart that I need to use a normal switched connection and this just refuses to work (both appliances on consecutive ports on the same switch). The connections come up and there are no errors on the switch ports or the appliances, but the heartbeat packets don't seem to get through. The odd thing is that if I swap the "ft-port vlan 10" command for a normal "switchport access vlan 10" command then it works fine.
Can anyone explain this weirdness? what exactly does the "ft-port" do?
thanks,
Andrew.
Syed Iftekhar Ahmed Tue, 10/07/2008 - 10:01
  • Blue, 1500 points or more
"ft-port vlan X" command simply makes that
port dedicated to FT traffic, it does not setup any kind of bridging or trunking.
If you are using cat6K then the the default for a port on a 6k is to trunk with another
switch.
Since the native default native vlan on any trunk is Vlan 1. and since you do not have any vlans assigned to that port, it is only pushing vlan1 traffic and vlan 10 is sitting
idle.
I think assigning Vlan 10 as the native will allow ACE to push the traffic onto the switch.
Try the following
ft-port vlan 10
switchport trunk native vlan 10
Syed Iftekhar Ahmed
andrew.burns Tue, 10/21/2008 - 07:41
Hi Syed,
I was using a Cat3550 switch, with the ports set up as normal access ports, like this:
interface FastEthernet0/35
switchport mode access
spanning-tree portfast
So, on the ACE I tried not using "ft-port" and just used "switchport access vlan 10" which worked fine, and the FT worked as expected. As soon as I use "ft-port" it breaks until I add the "switchport trunk native vlan 10" command. What's going on here? does the ft-port command turn the FT port into a trunk port? I'm definitely missing something here and the Cisco docs are not clear on this point.
thanks,
Andrew.
g-hopkinson Tue, 10/21/2008 - 06:04
Andrew,
Have you resolved this yet?
I have just setup two ACE4710's, same issue on FT connection. The reply about assigning the ft vlan to the interface is not an acceptable command.
The switches that I am using are 3750's, these are recording interface errors, and when you do a show int f4/0/47 controllers, you see the issue is related to runts, undersized packets. I have seen similar issues before on 3750's.
I have had to leave the FT connection as a cross over to make it work.
Any ideas?
Gary
Syed Iftekhar Ahmed Tue, 10/21/2008 - 11:09
From the following link
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/command/reference/if.html#wp1068700
"ACE automatically includes the FT VLAN in the VLAN trunk link"
It means FT ports are put by default in trunk mode. Could you guys change the ports on the switches to trunk port and see if it works.
Syed
