suschoud Tue, 10/07/2008 - 10:09
Please collect " sh crash " info. and paste it here.
Sushil
Richard Burts Tue, 10/07/2008 - 12:51
Sushil
I believe that what he attached to his post was the crashinfo.
oluwaseyi
Here is advice that was contained in the file that you posted:
An internal error occurred. Specifically, a programming assertion was
violated. Copy the error message exactly as it appears, and get the
output of the show version command and the contents of the configuration
file. Then call your technical support representative.
So you should prepare to open a case on this incident. I would guess that the solution may be to upgrade to a different version.
Rick
