ACL and Route-map work together?
Oct 7th, 2008
I have a route-map set up which redirects all port 80 traffic from 10.250.48.0/24 hosts to a web page which is routed on another router.
The route-map is placed on the vlan interface for the 10.250.48.0 vlan, and sets the next-hop as the IP address for the second router, where the redirect web page is routed.
The next-hop on that router for this traffic is the IP address of the redirect web page.
This works fine UNTIL I apply an extended ACL on the vlan interface for the 10.250.48.0 subnet. The ACL restricts access to certain networks and hosts, but it does explicitly allow all port 80 traffic.
As soon as I apply the ACL to the 10.250.48.0 vlan the redirect fails to work. Removing the ACL restores the redirect feature.
What am I missing here?
thanks!
Overall Rating: 5 (1 ratings)
Richard Burts Tue, 10/07/2008 - 10:28
Lynne
A route map is used in Policy Based Routing to examine traffic and to make a routing decision that effectively over rides the normal routing logic. Most of the time the route map makes use of an access list as the mechanism to identify the traffic. In this case any traffic permitted by the access list is policy base routed and any traffic not permitted in the access list is not policy base routed and uses the normal routing logic.
If your PBR stops working when you apply the access list then I would guess that there is a flaw in the access list and that it is not permitting the correct traffic. If you provide more details about your environment and the details of your PBR and the access list then perhaps we can make a suggestion about how to fix it.
Rick
lynne.meeks Tue, 10/07/2008 - 11:06
Sure. here you go:
Here's the PBR info:
route-map WirelessVPNInfo permit 10
match ip address 155
set ip next-hop 10.250.207.77
Extended IP access list 155
10 permit tcp 10.250.48.0 0.0.15.255 any eq www
20 deny ip any any
Here's the ACL; which does explicitly allow all port 80 traffic:
ip access-list extended packets-leaving-vlan15-10-07-08-01
remark scripts.uvm.edu
remark Hosting vpn.mobileconfig for iPhone
permit ip host 10.250.101.44 any
remark VPNINFO web redirect page
permit tcp any any eq www
permit ip host 10.250.101.25 any
remark Allow access to LWAPP controller
permit ip host 10.246.207.254 any
permit ip 10.246.207.0 0.0.0.255 any
remark DNS access
permit ip host 10.250.201.10 any
permit ip host 10.250.202.10 any
remark DHCP access
permit ip host 10.250.201.20 any
permit ip host 10.250.201.21 any
remark WINDOWS DOMAIN CONTROLLERS
permit ip host 10.250.102.5 any
permit ip host 10.250.102.6 any
remark LDAP access for Macs
permit ip host 10.250.101.196 any
remark VPN access
permit ip host 10.250.111.53 any
permit ip host 10.250.111.54 any
permit ip host 10.250.111.200 any
Here's the VLAN config,
interface Vlan15
ip address 10.250.48.1 255.255.240.0
ip helper-address 10.250.201.21
no ip redirects
ip dhcp relay information trusted
no ip route-cache
ip policy route-map WirelessVPNInfo
ip access-group packets-leaving-vlan15-10-07-08-01 out
mls rp vtp-domain UVMBackbone
no cdp enable
Lynne
Richard Burts Tue, 10/07/2008 - 11:27
Lynne
Thank you for the additional information which does help to clarify the issue. Seeing this and re-reading your original post I realize that I did not understand correctly your question and my answer was about something different from what you were really asking. I am sorry about that.
Having seen the access list and the config I now understand what you were really asking, and I believe that I have a better answer to your question. I believe that this is the line in question:
To get to the problem let us remember that when the client sends a request to the server that port 80 is the destination port. And that when the server sends a response to the client that port 80 becomes the source port. And since the access list is applied out on the VLAN interface it is permitting responses (rather than requests). So it needs to permit 80 as the source port and not as the destination port (which is what you have). I believe that if you change it to this you will find that it works:
permit tcp any eq www any
Rick
lynne.meeks Wed, 10/08/2008 - 03:46
BINGO!
that was exactly the problem.
I added the line permitting 80 as the source port, and it works perfectly.
Seems so obvious now, but I guess hindsight is 20/20.
Thanks for your assistance- much appreciated.
Richard Burts Wed, 10/08/2008 - 03:55
Lynne
Thanks for posting back to the thread and indicating that the problem was solved. I am glad that I was able to help you find the solution. Hindsight does tend to make things look simple when they were not nearly so obvious when it was an active issue. And the source port/destination port issue is an easy one to overlook.
Rick
