DHCP client is not working in 831 cisco router
Oct 7th, 2008
HI ,
I am having Cisco 871 router ISP is suggesting to put WAN interface is in DHCP mode So I have configured the IP address dhcp client ID in WAN ( fe/4 ). I am getting ip address and internet was fine after two day the internet is went down.
I have removed the configuration from WAN interface and I put it back that time the link is up and running. I have faced this same issue on three time. Please any on help on this
John Blakley Tue, 10/07/2008 - 12:07
  • Purple, 4500 points or more
Can you post your config? Take out all the necessary stuff.
thiru.vel10 Wed, 10/08/2008 - 11:56
WAN interface
interface FastEthernet4
description $ES_WAN$
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
IP router 0.0.0.0 0.0.0.0 fastethernet4
johnakeating Thu, 10/09/2008 - 23:54
get ride of the client ID unless that is something that was assigned to you.
ip address dhcp
John
thiru.vel10 Fri, 10/10/2008 - 09:32
I have tried that command but still I am having the same problem.
Thiru
John Blakley Fri, 10/10/2008 - 09:40
Is this a PPPoE account? Can you post your config, and a debug of dhcp?
John Blakley Fri, 10/10/2008 - 09:41
Can you do a:
sh ip int fa4
Please post results....
John
thiru.vel10 Fri, 10/10/2008 - 10:17
Already i have posted the configuration .
I am using cisco 871 router, modem is directly connected to Cisco router wan interface, modem in bridge mode and I am putting DHCP mode in router wan interface. So IP address is getting from ISP and I am able to access the internet. That IP is mapped with my router WAN interface MAC address. But some time I am not able to get the IP address that time I am just removing and revert the config , after that I am getting IP address. My observation is some time router is not sending the request to ISP ? here with I am attaching the configuration for your reference
WAN interface
ip nat outside
duplex auto
speed auto
John Blakley Fri, 10/10/2008 - 10:20
The only thing that I can tell you is that if it works after you remove and reapply the config is that you should run debugs on dhcp. I would try to leave the config, close and open the interface (shut/no shut), and see if you get an address again.
Check your cables too. We've seen some weird things happen with a flaky cable.
thiru.vel10 Fri, 10/10/2008 - 21:46
Hi have checked cable and I replaced the cable with new one. But I didn't ran the command Debug DHCP. Let me run and let you know. I have tried the command shut and no shut no luck same state only .
thiru.vel10 Mon, 10/13/2008 - 08:30
One thing I want to share with you all. Wan interface status showing up after disconnecting the cable …. ..
