Problem with 3560 switch
Oct 7th, 2008
i have a a switch with a corupted image on it, i did the steps of sending a new image through the xmodem ..
but i booted from the new image i got this msg
Loading "c3560-ipbasek9-mz.122-25.SED1.bin"...c3560-ipbasek9-mz.122-25.SED1.bin: no such device
Error loading "c3560-ipbasek9-mz.122-25.SED1.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipbasek9-mz.122-35.SE5.bin"...@@@@@@@@@@@@@
i don't know why its looking for the old ios ...
also when i reloded the switch and get the switch# prompt, i did show runn i noteced a command on some ports which i didn't put ( i have configured the vlans and other stuff butt didn't configuer this vlan)
switchport trunk pruning vlan 2-941,943-1001
please see the attached for more information
Overall Rating: 4 (2 ratings)
lamav Tue, 10/07/2008 - 13:59
Can you execute the following commands and post the output?
sh ver
sh flash
sh boot
dir /all
enkli Fri, 10/10/2008 - 00:07
you must enter config mode and then
boot system flash:/your_new_image.
write te config and then reload.
rate if it helps
serenity001 Fri, 10/10/2008 - 00:14
thx ,
will do it then will give you the feed back
but also after rebooting, and issuing show runn
i see this command under some of the interfaces
and i didn't write tis command ever..
enkli Fri, 10/10/2008 - 00:30
I think you are rely on an old config.
but you can also disable pruning.
serenity001 Fri, 10/10/2008 - 08:05
thank you
but still i have a problem :(
see this
interface FastEthernet0/7
switchport access vlan 44
switchport trunk allowed vlan 1-4077,4079-4094
switchport mode access
i didn't issue the trunk command ... is it a bug??
enkli Tue, 10/14/2008 - 00:45
I think that they arent issued themselves.
disable this config.
It might have be an error or bug if not an security issue
