Match Outgoing SIP Dial-Peer based on source caller
I have an environment with several remote sites. I would like each site to have it's own outgoing dial-peer so that each can have it's own number translations and redirections.
So how can I match a dial peer based on the source caller? each site has a differenet extension range (1xx, 2xx, 3xx, etc.) So i am hoping i can setup my dial peers to say 'caller is 100, use dial peer 1. caller is 200, use dial peer 2'.
Any help would be appriciated.
Marwan ALshawi Tue, 10/07/2008 - 17:20
if u have a case like
this way u can match based on clling number as following
dial-peer voice 91 voip
answer-address 1..
session target
dial-peer voice 92 voip
answer-address 2..
session target
dial-peer voice 93 voip
answer-address 3..
session target
the idea is the use of answer address and u can put for each dia-peer its own translation profile--codec target and so on ...
good luck
if helpful Rate
I have tried using the answer-address, and it doesnt appear to have any effect.
I have a UC500 box, connected to an external SIP provider.
I have dial-peers setup just as you describe, however all calls are going through the first DP. If i shutdown this DP, the calls go through the second one just fine (and apply translations as designed).
So the answer-address does not appear to be solving my problem of picking an outgoing DP based on the internal extension (site) making the call.
Marwan ALshawi Mon, 10/20/2008 - 17:39
no no
the naswer-address should be used in an incoming dial-peer !!
the is the thing
u can apply trnaslation pattren in CME on phone level as well !!!
so u can match the called number by that phone and translated as with dial-peer but on ephone level
Marwan ALshawi Mon, 10/20/2008 - 22:14
it is a way to use it
which is right for sure
but when u have time to test try to make translation profile apply it in the inbound for answer-address or as i told u could use translation on the phone level as well
to advancce ur skills in this area :)
then let me know
good luck
