VTP,STP,Conversion from hybrid to native
Oct 7th, 2008
Hi ALL:
I will be convrting 6513 from Hybrid to Native Mode.
I have used the EDC tool for conversion,but i have some confusion.
1.Should i be adding the switch in transparent mode or server
2.In the config the VTP mode is server and MST but i dont see any MST configured.
3.Spanning tree is Spanning tree mode: RAPID-PVST+ and not MST
4.In the config i have used command set spantree disable 1 (VLAN) for all my vlan.
5.Then why i see this is Root switch for vlans: 1-2,5-6,10,20,25,30,35,40,100,120,150,180,240-241,300,320.
6.What is the best way to configure VTP and STP based on this output
****************** show vtp domain ******************
Version : running VTP2 (VTP3 capable)
Domain Name : xxxxxxxx Password : not configured
Notifications: enabled Updater ID:
Feature Mode Revision
VLAN Server 61
Pruning : enabled
VLANs prune eligible: 2-1000
VTP CONFIGURATION
set vtp domain xxxxxxx
set vtp mode server mst
set vtp version 2
set vtp pruning enable
****************** show spantree active ******************
VLAN 1
Spanning tree disabled
Bridge ID MAC ADDR 00-0f-f8-10-02-00
Bridge ID Priority 32769 (bridge priority: 32768, sys ID ext: 1)
Bridge Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Port State Role Cost Prio Type
1/1 forwarding MSTR 4 32 P2P
1/4 forwarding MSTR 4 32 P2P
2/32 forwarding MSTR 4 32 P2P
2/38 forwarding MSTR 4 32 P2P
3/8 forwarding MSTR 4 32 P2P
3/45 forwarding MSTR 4 32 P2P
3/47 forwarding MSTR 4 32 P2P
4/13 forwarding MSTR 19 32 P2P
5/20 forwarding MSTR 19 32 P2P
5/24 forwarding MSTR 19 32 P2P
5/35 forwarding MSTR 19 32 P2P
5/37 forwarding MSTR 19 32 P2P
5/48 forwarding MSTR 19 32 P2P
****************** show spantree summary ******************
Runtime MAC address reduction: enabled
Configured MAC address reduction: enabled
Global loopguard is disabled on the switch.
Global portfast is disabled on the switch.
BPDU skewing detection disabled for the bridge.
BPDU skewed for vlans: none.
Portfast bpdu-guard disabled for bridge.
Portfast bpdu-filter disabled for bridge.
Uplinkfast disabled for bridge.
Backbonefast disabled for bridge.
L2PDU rate limiter is disabled.
#spantree TREE CONFIGURATION
#vlan parameters
set spantree disable 2
set spantree disable 5
set spantree disable 6
set spantree disable 10
set spantree disable 20
set spantree disable 25
set spantree disable 30
set spantree disable 35
set spantree disable 40
set spantree disable 100
set spantree disable 120
set spantree disable 150
set spantree disable 180
set spantree disable 240
set spantree disable 241
set spantree disable 300
set spantree disable 320
Thanks in advance
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Wed, 10/08/2008 - 09:28
  • Hall of Fame,
    Founding Member
Hello Vishwa,
1) changing the vtp domain to a different one and mode to transparent and then back right domain and mode to server to be sure to have revision number zero: but booting to Native IOS for the first time should give you this
2) config as vtp server, mst extension is VTPv3 stuff not supported in Native IOS ignore it
3) yes RSTP use it in line with the rest of the network (as it has been up to now)
4) I strongly disagree : let RSTP enabled for all vlans no reason to do this
5) maybe because you are using RSTP but again I recommend to have RSTP enabled for all vlans
6)
as told above
vtp server
RSTP enabled on all vlans : don't convert the spantree disable command
Finale note:
the conversion tool is not trusted by everyone some other collegue has suggested to convert manually
I did so in my own few conversions
hope to help
Giuseppe
vishwancc Sun, 10/12/2008 - 01:33
Thanks Giuseppe for your response.
I activity got over successfully.
