Is HSRP officially supported on a VG224?
Oct 7th, 2008
What is Cisco's official recommendation with regards to running HSRP or Bridge Groups on a VG224?
We want to try and dual home both NICs to the core, but only if Cisco supports it...
allan.thomas Mon, 10/13/2008 - 12:51
  • Blue, 1500 points or more
Accordingly to the following Technical Specification these protocols are supported on the VG224 including HSRP:-
PROTOCOLS SUPPORTED
• SCCP
• H.323v4
• MGCP
• SIP
• Real-Time Transport Protocol (RTP)
• Secure Real-Time Transport Protocol (SRTP)
• Trivial File Transfer Protocol (TFTP)
• HTTP server
• SNMP
• Telnet
• Dynamic Host Configuration Protocol (DHCP)
• Domain Name System (DNS)
• Cisco Unified CallManager 3.3.3 SR2 or higher version
• Cisco Unified CallManager Express 4.3.2 or higher version
• Cisco Unified CallManager or Cisco Unified CallManager Express redundancy support using Hot Standby Router Protocol (HSRP)
• Call survivability-MGCP failover to an H.323 connection to the SRST router
• Cisco fax relay, T.38 fax relay, and modem pass-through
• Coder/decoder (codec) support, G.711, G.729a
• RADIUS and TACACS+ for Telnet and authorization
Refer to the following URL:-
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/ps5516/product_data_sheet09186a00801d87f6.html
Rgds
Allan.
