configuring CIR & MIR
Oct 7th, 2008
I am trying to configure the CIR and MIR of a DSL user. Just want to verify if my configuration below is correct. Assuming the CIR is 64K and MIR is 88K. Under policy-map, I configured these:
bandwidth 64
shape peak 88
Will it work as expected?
Thanks..
Your configuration would result in the following if you used 88 as 88000 (bits per second under shapers)
During congestion = BW guarantee of 64K
Always in effect = Shaping Policy = 88K Average with a burst excess of 88K = 176K Peak (88K CIR/176K Port) total if interface has BW available during the interval (default every 25ms or 1/40th of a second).
If you want to limit max to 88K, then use
shape average 880000
