Chawki Salhi Wed, 10/08/2008 - 05:15
Yes you can! what you have to do is to collect the ANI and then do a switch on the different values it can take. Don't forget to add a default treatment. Each branch can then be routed specifically.
With best regards,
Chawki
rodneygonsalves Wed, 10/08/2008 - 13:17
Thanks Chawki.
But I was not sure the way the ANI collection should be used i,e
Use the "call contact info" and get the calling number, however should the value (i.e the ANI) can be written as a whole number i,e "0282314000" or "02xxxxxxxx" for all the number starting with 02.
Chris Deren Wed, 10/08/2008 - 06:13
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Absolutely, you can callect ANI, and then use IF statemnt such as (ANI.beginswith("02") and ANI.length() = 10) OR (ANI.beginswith("03") and ANI.length() = 10). I may be off on the method syntax, but that's the idea.
HTH,
Chris
rodneygonsalves Wed, 10/08/2008 - 15:24
Thanks Chris.
I was looking for the syntax for the above and unable to get into the scripting guide.
Are then are any other docs that can be referred ?
