ACS v4.0 backup
Answered Question
Oct 7th, 2008
I am using acs v4.0 and I have scheduled the backup , my problem is that the scheduled backup works for 3 weeks and then it stops ,after that I have to do it manually after that again the automatic backup starts i do not have any hard disk space problem - can any body help me
Correct Answer by Jagdeep Gambhir about 8 years 4 months ago
I have seen this issue before and was able to recreate it. There is bug for this marked as unreproducible. CSCse52276 : Externally found moderate defect: Unreproducible (U)
As a workaround schedule backup for twice a week and that should work fine.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
craig.eyre Wed, 10/08/2008 - 08:02
Is there anything showing up in your ACS backup log that gives any indication of an issue?
Craig
Correct Answer
Jagdeep Gambhir Mon, 10/13/2008 - 05:39
~JG
muralee29477 Sat, 10/25/2008 - 00:22
Tks a lot for your response and I tried it is working now
regards
muralee
