Cisco 1841 Crashing / Running Out of Memory (maybe)
Oct 8th, 2008
I have a Cisco 1841 that has 8 VPN's running through it (it is not the tunnel endpoints though), it also provides internet access for the main office through a 10 Mb leased line.
It keeps crashing every few days with this appearing in the Syslog :
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 50: Pool: Processor Free: 206548 Cause: Memory fragmentation
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 51: Alternate Pool: None Free: 0 Cause: No Alternate pool
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 52:
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 53: -Process= "ARP Input", ipl= 3, pid= 10
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 54: -Traceback= 0x608DD040 0x601FBB28 0x60200C38 0x6021A5CC 0x60245E38 0x602466D8 0x60246960 0x60A63A3C 0x60A69720 0x60A6D4A4 0x60A6DB3C 0x60696374 0x60A9529C 0x60C0F518 0x60C0FB24 0x60C10614
2008-10-06 09:00:14 Local7.Critical 212.240.x.x 49: 000046: *Oct 6 08:03:50: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x6021A5C4, alignment 16
2008-10-06 09:00:15 Local7.Error 212.240.x.x 55: 000047: *Oct 6 08:03:50: %FIB-3-NOMEM: Malloc Failure, disabling CEF
2008-10-06 09:00:15 Local7.Error 212.240.x.x 56: -Traceback= 0x608DD040 0x60A63AA4 0x60A69720 0x60A6D4A4 0x60A6DB3C 0x60696374 0x60A9529C 0x60C0F518 0x60C0FB24 0x60C10614 0x606A3AF0
2008-10-06 09:05:29 Local7.Error 212.240.x.x 61: 000052: *Oct 6 08:09:02: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
From what I have read, this error normally indicates that the Processor pool is running out of memory - I have tried 'memory-size iomem 5' but it still keeps crashing.
I have also swapped the router with a different one (1812) and upgraded the firmware - still the same result. If i disable CEF it lasts a week before it crashes, this time with nothing in the syslog.
I am now looking to upgrade the internal memory - will this fix the problem ?
Overall Rating: 4 (2 ratings)
satish_zanjurne Wed, 10/08/2008 - 01:43
Explanation: This device has recorded a %SYS-2-MALLOCFAIL: error message.
This error indicates a memory allocation failure. Memory allocation of [dec] bytes
failed from [hex], alignment [dec] Pool: [chars] Free: [dec] Cause: [chars] Alternate
Pool: [chars] Free: [dec] Cause: [chars] The requested memory allocation is not
available from the specified memory pool. A memory allocation failure occurs in
one of these situations:
- The current system configuration, network environment, or possibly a software
error may have exhausted or fragmented the router's memory
- When the router uses up all available memory (temporarily or permanently)
- When the memory is fragmented into such small pieces that the router cannot
find a usable block. This issue can occur with the processor memory or with the
packet memory. This error can occur due to a variety of reasons that include:
* Incorrect configuration
* Too many features enabled for a small amount of memory
* A single process that consumes more memory
Recommended Action: Begin to troubleshoot with a check on the process that the
error message mentions. Submit the output of show process cpu and show memory
commands to Output Interpreter to check whether the process consumes more memory.
If you are unable to reproduce the error message, you can ignore the error message.
If the error message recurs, review the Bug Toolkit to locate any software bugs
that can cause this error.
HTH...rate if helpful..
tonysweeney@ncs... Wed, 10/08/2008 - 02:06
Thanks for the reply, the configuration is really basic, and there are no advanced features enabled really. I have also tried two different routers with two firmwares so it's unlikely to be a bug ?
Here's th config, is there anything that sticks out ?
Current configuration : 3354 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname x
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 X
no aaa new-model
resource policy
memory-size iomem 5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip bootp server
no ip domain lookup
ip domain name X
interface FastEthernet0/0
description External Connection to THUS
bandwidth 81920
ip address 193.195.x.x 255.255.255.252
ip access-group 100 in
no ip proxy-arp
ip route-cache flow
speed 10
full-duplex
interface FastEthernet0/1
description Internal - Connection to Sonicwall
ip address 212.240.x.x 255.255.255.248
no ip proxy-arp
ip route-cache flow
speed 100
full-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 212.240.x.x 9996
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 212.240.202.202
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 permit tcp host 83.104.x.x host 193.195.x.x eq telnet
access-list 100 permit tcp host 83.104.x.x host 193.195.x.x eq 22
access-list 100 permit tcp host 83.104.x.x host 193.195.x.x eq www
access-list 100 permit tcp host 83.104.x.x host 193.195.x.x eq 443
access-list 100 permit tcp host 83.104.x.x host 193.195.x.x eq cmd
access-list 100 deny tcp any host 193.195.x.x eq telnet
access-list 100 deny tcp any host 193.195.x.x eq 22
access-list 100 deny tcp any host 193.195.x.x eq www
access-list 100 deny tcp any host 193.195.x.x eq 443
access-list 100 deny tcp any host 193.195.x.x eq cmd
access-list 100 deny udp any host 193.195.x.x eq snmp
access-list 100 deny tcp any any range 6881 6999
access-list 100 permit ip any any
no cdp run
control-plane
banner login ^C
Authorized Access Only!
If you are not authorized to use this system please disconnect now.
All access attempts are logged. ^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 102 in
privilege level 15
login local
end
Maybe I just need to upgrade the memory ?
netwalkr1 Wed, 10/08/2008 - 06:31
Change the default route to the next hop IP address. When you use a default route next hop as the interface on an Ethernet environment it will populate the ARP table with each destination. This consumes the routers RAM.
tonysweeney@ncs... Wed, 10/08/2008 - 07:29
Thanks, I have changed the default route -
the arp table never grows to more than 5 entries though because it is a straight link with the ISP.
tonysweeney@ncs... Wed, 10/08/2008 - 09:22
For some reason, the number of buffer elements on the free list is way over the max, could this be related somehow ?
#show buffers
Buffer elements:
1117 in free list (500 max allowed)
21421 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
49 in free list (20 min, 150 max allowed)
11963 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25):
23 in free list (10 min, 150 max allowed)
960 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 50, permanent 50):
49 in free list (5 min, 150 max allowed)
2608 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 100 max allowed)
Large buffers, 5024 bytes (total 0, permanent 0):
0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
0 in free list (0 min, 4 max allowed)
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
256 in free list (128 min, 1024 max allowed)
512 hits, 0 misses, 0 trims, 0 created
512 max cache size, 512 in cache
29 hits in cache, 0 misses in cache
Particle Clones:
1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
0 hits in cache, 0 misses in cache
Normal buffers, 1548 bytes (total 768, permanent 768):
768 in free list (128 min, 1024 max allowed)
Private particle pools:
FastEthernet0/0 buffers, 1552 bytes (total 512, permanent 512):
0 in free list (0 min, 512 max allowed)
512 hits, 0 fallbacks
512 max cache size, 256 in cache
1703973 hits in cache, 0 misses in cache
FastEthernet0/1 buffers, 1552 bytes (total 512, permanent 512):
2123246 hits in cache, 0 misses in cache
tonysweeney@ncs... Thu, 10/09/2008 - 03:02
Thanks, I have read that guide before but did not change anything since the buffers are, like you say, usually empty.
Yes the router is in production, but it is used mainly for routing CCTV video so the traffic is very bursty - normally the link is barely utilised but sometimes jumps up to 10 Mb very quickly depending on how many camera's are utilized.
I guess I will open a service case with Cisco since the router is still crashing, I don't know why when usually the 10 Mb connection is usually using less than 1Mb of bandwidth.
