1020 booting loop.....Help
Oct 8th, 2008
I have upgraded my controller to 4.2.130, and then I attempted to give one of my AP's a static IP address, and since then its in a booting loop.
I partially registers with the controller, and then reboots itself, and I cant ping it or reset the config.
What options do I have?
David
Scott Fella Wed, 10/08/2008 - 03:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What does the log show. You can see a join, but what error do you see after that. make sure the time is set correctly on the wlc, verify that there is not any ap authorization configured that may be blocking the ap from joining. Here is a doc you can go over to make sure you are setting up the network and wlc correctly:
http://www.cisco.com/en/US/docs/wireless/access_point/1000/quick/guide/ap1000qs.html#wp34036
dazzo Wed, 10/08/2008 - 06:12
Thanks for your advice.
I managed to work out using the debug commands that the static IP was using a different subnet mask to the AP-Manager
Cheers
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
