Unity Express Group Mailbox Greeting
Answered Question
Oct 8th, 2008
I made a group and added a new group mailbox. I want to change the greeting message. I can not figure out how to put a PIN code for my group.
Can you please help?
Thanks in advance,
Ruben de Haas
Correct Answer by Markus Schneider about 8 years 3 months ago
When you add a group mailbox, you need to assign members to that group. Once that's done, then each member can log into their own personal mailbox and will then be presented another option (9) to access the group mailbox(es). From there, the greetings can be changed.
Overall Rating: 5 (1 ratings)
Correct Answer
Markus Schneider Wed, 10/08/2008 - 04:31
rubendehaas Wed, 10/08/2008 - 04:44
Hi Markus,
Thank you very much for the solution!
It works!
Best regards,
Ruben de Haas
