10-08-2008 03:43 AM - edited 03-15-2019 01:48 PM
I am running CUCM 6.1.2 and have configured IPMA shared line, I'm having a problem that when I open the assistant console the directory is empty, I presume this should be the same as the attendant console and have a full list of the global directory. Has anyone else come across this problem?
Thanks in advance
Paul
10-14-2008 12:55 PM
Is your system AD integrated? Which IPMA mode are you using? Shared mode? Proxy mode?
10-15-2008 10:55 AM
I'm using shared mode, I have logged onto the same PC and opened up Attendant Console and it has the full directory so it's not a setting with the pc which I suspected...
It's not AD integrated, it's a voicemail only solution with AD users created on the Unity locally for vm users..
Paul
