Need help on basic setup
Oct 8th, 2008
New to Cisco VoIP but been doing SIP for several years now. Here is what I have and what I need.
Cisco 2801 with c2801-advipservicesk9-mz.124-20.T1.
Fa0/0
ip 10.10.10.1/24
Fa0/1
ip 10.98.5.247/23
I have a PC with Xlite softphone
10.10.10.2
Extention 2002
I got the Xlite to register to the router, but trying to route all external calls to a specific IP 10.98.5.245 which is a Acme SBC.
Here is my setup. Can someone tell me what I'm doing wrong?
Router#sh run
Building configuration...
Current configuration : 3965 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$DiN8$kyxjpdY/DaGEuqzTFrqlr1
no aaa new-model
memory-size iomem 20
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice service voip
allow-connections sip to sip
redirect ip2ip
sip
registrar server
no call service stop
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 30
max-pool 20
authenticate register
voice register dn 1
number 2002
allow watch
name xlite
label test
mwi
voice register pool 1
id mac 0002.B330.B04A
number 1 dn 1
presence call-list
dtmf-relay rtp-nte sip-notify
username 2002 password 2002
codec g711ulaw
voice-card 0
username cisco privilege 15 secret 5 $1$2ssP$haAS0QsYZMyhfSp61rqKl.
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.98.5.247 255.255.254.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.98.4.1
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip http path flash:/html
control-plane
dial-peer voice 2000 voip
description "outbound"
destination-pattern 16137330000
b2bua
session protocol sipv2
session target ipv4:10.98.5.245
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 2001 password 7 115B495546 realm none
authentication username 2002 password 7 1357474259
telephony-service
max-ephones 20
max-dn 20
ip source-address 10.10.10.1 port 5060
max-conferences 8 gain -6
web admin system name pipsadmin password pipsadm
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 2
number 2002
label 2002
description 2002
name 2002
hold-alert 30 originator
ephone 1
device-security-mode none
line con 0
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Overall Rating: 5 (2 ratings)
Brandon Buffin Wed, 10/08/2008 - 10:13
  • Purple, 4500 points or more
Currently, dial peer 2000 will only send calls to 16137330000 out the SIP trunk. If you are not using an access code such as 9 and you want to send all calls to the SIP provider, you can use "destination-pattern .T".
Hope this helps.
Brandon
pipsadmin Thu, 10/09/2008 - 05:06
Thanks !
WHere can I get more info on the patterns?
