Incoming calls disconnect very ofen
Oct 8th, 2008
Our client using Cisco 3600 Router + Isdn Qsig Voice Card + Gatkeeper
All clients are registring into the cisco gatekeeper.
Problem facing : Some times No Incoming calls, Enpoints are registered.
Q931 Debug:
Oct 8 11:29:01: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x6059
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98389
Exclusive, Channel 9
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '348741246'
Plan:ISDN, Type:National
Oct 8 11:29:01: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xE059
Oct 8 11:29:01: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xE059
Cause i = 0x80FF - Interworking error; unspecified
Oct 8 11:29:02: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x6059
Oct 8 11:29:02: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xE059
Oct 8 11:29:03: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xADD9
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Please help me on this issue
sebastiandm Wed, 10/08/2008 - 07:20
What CM version are you running ? Have you checked your interfaces are clear of errors/slips.
brandoncheah Wed, 10/08/2008 - 07:34
What commands do you use if you wanted to check your serial interfaces of errors/slips?
