Trunk advise
Oct 8th, 2008
I have a 3750 switch that is full and FE0/2 is in do1q trunk to a 3550 which is also full apart from one port.
I have a 2960 and I want to add more vlans and extend some of the 3750 vlans to this, can I trunk off the 3550? Will the vlan tags from the 3750 to 3550 trunk extend through to this 3rd switch?
I am not using VTP server/client mode, currently both switches are in the default server mode.
Just wondered how you would appraoch this one?
serenity001 Wed, 10/08/2008 - 05:26
if you use VTP it will be easy task for u ..
configure the 3750 as a vtp server and the other switches as vtp clients..
Marwan ALshawi Wed, 10/08/2008 - 05:28
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
first if u look to make the siwtch vlan conifg be done independently not thorugh server/client
then i would suggest u to make them in transparante mode first
then define the vlans on each switch
then add the trunk ports as required
then the vlans on L2 will span ur netwrk if u wanna make intervlan routing u can as well
good luck
if helpful Rate
whiteford Wed, 10/08/2008 - 06:03
This sounds siilar to my setup already, what is the difference from my mode (server default only) and tranparent mode?
Marwan ALshawi Wed, 10/08/2008 - 06:14
transperant mode mean the switch will not send or recieve valn update from other switches within the vtp domain onlly pass it
while server send the updates to clients and client only recieve from server
but when u have more than one switch in server mode the will be high possibilty to have problem because the switch in server mode with higher revesion number will send the update of vlan database and overwrite others in the same domain except those in transeparant
if u wanna see the revesion number
show vtp status
if u wanna rest the revesion number to 0
just renaim the vtp domain and get it back to the original name
if helpful Rate
