Saving Public IP Address - CSS
b.petronio
Level 3
Level 3
Hello all,
I'm leading with a problem relating the nº of public services my client is offering.
Before me, they was applying one public ip address for each web-server, and therefor "nating" for the CSS Vip Address.
This was turned around by in the http mode, but when they need ssl termination on CSS, i still have this problem.
The configurtion for the HTTP mode is like this:
tst.example.com and dsv.example.com = 10.1.1.139
******** OWNER EXAMPLE ********
content HTTP-tst.example.com
redundancy-l4-stateless
advanced-balance arrowpoint-cookie
arrowpoint-cookie browser-expire
balance weightedrr
vip address 10.1.1.139
protocol tcp
port 80
url "//tst.example.com/*"
add service server1-8888
active
content HTTP-dsv.example.com
balance weightedrr
protocol tcp
port 80
url "//dsv.example.com/*"
add service server1-7777
active
******** SERVICES ********
ip address a.b.c.d
port 7777
keepalive type http
keepalive uri "/"
keepalive port 7777
active
ip address a.b.c.d
port 8888
keepalive type http
keepalive uri "/"
keepalive port 8888
active
************* SSL ****************
content SSL-*.example.comp
add service MODSSL
application ssl
protocol tcp
port 443
url "/*"
advanced-balance ssl
active
service MODSSL
slot 2
type ssl-accel
keepalive type none
add ssl-proxy-list ssl1
active
ssl-server 110
ssl-server 110 vip address 10.1.1.139
ssl-server 110 rsacert tstcert
ssl-server 110 rsakey tstkey
ssl-server 110 cipher rsa-export-with-rc4-40-md5 10.1.1.139 80
This works fine for HTTP, but when i tried to put HTTPs, i putted 1 content to match the VIP Address and the 443 PORT, to one proxy server only, cause i dont found a way of filtering a "url" for the same VIP Address.
The issue is that, when a client is hitting the dsv.example.com, the certificate is saying, tst.example.com or vice-versa.
Is there a way to solve this issue ?
For sure i'm not seeing some basic thing, cause i think this could be easily done.
Best Regards,
Petrónio
Gilles Dufour
There is no way to solve this issue because https was designed to guarantee that your site is not hacked...therefore a certificate is linked to a domain name which is linked to a single ip address.
So, you will need to use 1 ip for each website that requires SSL.
Another solution is to request a special certificate which is for *.example.com.
This certificate is valid for all websites under your domain example.com
Gilles.
Gilles Dufour
Gilles.
Once again, thank you for your explanation.
The special certificate you mentioned, i call it a domain certificate.
Is there any different procedure when i create it, beside the common name ?
*** Is this correct ? ***
Common Name (your domain name) [www.acompanyname.com]*.example.com
or should i write ".example.com", only ?
Best Regards,
Petrónio
The exact name is a Wildcard Certificate.
So, I believe it should be *.yourdomain.com
http://www.rapidssl.com/ssl-certificate-products/rapidssl/usd/wildcard-ssl-certificate.htm
Gilles.
