CSM 3.2.1 Remote Access VPN and dedicated IP Address
we recently switched our ASA administration from ASDM to CSM 3.2.1.
In the ASDM you can set for VPN Useraccount the Group Policy, a dedicated IP address etc.
The problem is, I don't find that in the CSM!
In the masks of the user accounts I can only set the password and the priv level.
Any Idea? Do I have to switch for this configuration back to ASDM?
amritpatek Tue, 10/14/2008 - 06:37
When you configure a remote access IPSec or SSL VPN connection, you must create user groups to which remote clients will belong. A user group policy is a set of user-oriented attribute/value pairs for remote access VPN connections that are stored either internally (locally) on the device or externally on an AAA server. The connection profile uses a user group policy that sets terms for user connections after the connection is established. Group policies let you apply whole sets of attributes to a user or a group of users, rather than having to specify each attribute individually for each user.Using ASDM will be a better choice.
