Mutual Authentication through ASA
Oct 8th, 2008
Is it possible for clientless VPN clients to connect to web sites inside the VPN that require mutual authentication? I have a site running tomcat which demands a cert from the user's browser. This setup works when i connect directly to the site from my desktop, but through the clientless SSL VPN I get a connection failure when I browse to that site. Is there anything that must be done to the ASA to allow two way SSL authentication?
Thank You
cedricthehack Thu, 10/09/2008 - 06:33
I hadn't but that did end up being the proper solution. I added a bookmark to my site and in the bookmark settings checked the smart tunnel option. After that certs passed no problem. Thanks!
