Voicemail.aef from Script Repositry
Oct 8th, 2008
I am using the voicemail.aef script from the Cisco script repositry to be able to leave a voicemail in queue and have it delivered to the next available agent. I have it working fine when my license is Enhanced but it won't run when using a Standard license. I've looked thru the script and can't find any steps that aren't available in standard. I'm wondering if this is something similar to the holiday script that works ok on V3.5 std but not on V4.0 std and something about java steps no longer being available. The version of IPCC I am running is 5.02 and CCM 6.1.2. Any suggestions appreciated.
esa786_2 Tue, 10/14/2008 - 17:45
Hi. I think you need IPCC Express(UCCX) enhanced or premium license for this to work.
