incoming call problem
Oct 8th, 2008
I have a cm 6.1.2, the problem is that when i receive an international missed call i can not reial the number because the 00 is missing from the number (example: 944161....)
The call manager is connected to pstn gateway but there are no translation rules that affect the international numbering.
Can you please advice.
Thank you.
Marwan ALshawi Wed, 10/08/2008 - 15:50
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
ok the following link very nice and will guid u set by step to do this although it is for version 4 but the idea exactly yhte same and in this link they add 9 for missed calls u can make 00 and the matching number u can make it more spicific for international calls to get it work corectly have a look :
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
good luck
if helpful Rate
michalis1234 Thu, 10/09/2008 - 06:50
I have tried what you told me. But it did not work.
In front of the call manager we have a voice gateway (2811 router) connected to a pri line from the telco.
I think the best is to change the translation rules we have our translation rules are:
translation-rule 1
Rule 0 ^0.% 90
Rule 1 ^1.% 91
Rule 2 ^2.% 92
Rule 3 ^3.% 93
Rule 4 ^4.% 94
Rule 5 ^5.% 95
Rule 6 ^6.% 96
Rule 7 ^7.% 97
Rule 8 ^8.% 98
Rule 9 ^9.% 99
Rule 10 ^00.% 900
The last statement i added for testing.
I our country the dialling plan for land line is 2xxxxxxx (8numbers), for mobiles is 9xxxxxxx.
I believe this translation rule is only for local dialling ?
Can i create a another dial rule for international numbers and applied to the same dial peer ?
I will show you the dial peers:
translation-rule 1
Rule 0 ^0.% 90
Rule 1 ^1.% 91
Rule 2 ^2.% 92
Rule 3 ^3.% 93
Rule 4 ^4.% 94
Rule 5 ^5.% 95
Rule 6 ^6.% 96
Rule 7 ^7.% 97
Rule 8 ^8.% 98
Rule 9 ^9.% 99
Rule 10 ^00.% 900
translation-rule 2
Rule 1 1000 1297
Rule 8 1222 1296
Rule 9 1200 1296
Rule 10 1010 1298
translation-rule 3
Rule 1 1000 1005
Rule 2 1200 1201
Rule 3 1222 1201
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-I
ip address 192.168.x.x 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id PSTN_GATEWAY
h323-gateway voip bind srcaddr 192.168.x.x
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
ip mroute-cache
no logging event link-status
isdn switch-type primary-net5
isdn timer T310 60000
isdn incoming-voice voice
isdn sending-complete
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.x.x
control-plane
voice-port 0/0/0:15
translate called 2
echo-cancel coverage 32
cptone CY
bearer-cap Speech
dial-peer cor custom
dial-peer voice 3 pots
destination-pattern 9T
progress_ind alert enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 5 pots
destination-pattern 516T
direct-inward-dial
port 0/0/0:15
dial-peer voice 6 pots
destination-pattern 517T
direct-inward-dial
port 0/0/0:15
dial-peer voice 7 pots
destination-pattern 518T
direct-inward-dial
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern 515T
direct-inward-dial
port 0/0/0:15
dial-peer voice 1 voip
shutdown
destination-pattern 1...
translate-outgoing calling 1
voice-class codec 2
voice-class h323 1
session target ipv4:192.168.x.x
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 1
shutdown
voice-class codec 2
voice-class h323 1
no vad
dial-peer voice 10 pots
destination-pattern 7T
direct-inward-dial
port 0/0/0:15
dial-peer voice 60 voip
destination-pattern 1[6-9]..
voice-class codec 10
session target ipv4:10.1.x.x
dial-peer voice 100 voip
preference 2
destination-pattern 1199
voice-class codec 3
session target ipv4:10.0.x.x
fax-relay ecm disable
fax protocol t38 ls-redundancy 0 hs-redunda
no vad
dial-peer voice 150 voip
destination-pattern 1299
voice-class codec 2
voice-class h323 1
no vad
dial-peer voice 1000 voip
preference 1
voice-class codec 2
voice-class h323 1
no vad
Can you please advice..
