Telmex (MX) login paramater for DSL / Cisco 877
Oct 8th, 2008
Hello Folks!
I have a problem replacing a 2Wire 2701HG-T by a Cisco 877...
At the 2 wire the login configuration for adsl is pretty simple and does not tell you much about details.
As far displayed:
Connection Type: PPPoE
Circuit Information: VPI=0 VCI=35
Encapsulation: LLC as brige
Search ATM PVC: on
MAC: Using the direction of embedded hardware
IP: DHCP/Obtain IP address automatically.
I could not find a way to set up the Cisco 877 to log in, DSL carrier is detected, but that's it.
Does anybody have information about the correct log in configuration for TELMEX Mexico?
Thank you in advance.
B ert
