Hello Tony,
you cannot have a router in two BGP ASes at the same time
You can pretend to be in another As using:
neigh xxx local-as yyy
see what happens:
RT-RM-TLD066-DMZ-C-1#sh ip prot sum
Index Process Name
0 connected
1 static
2 isis
3 bgp 8234
*** IP Routing is NSF aware ***
RT-RM-TLD066-DMZ-C-1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
RT-RM-TLD066-DMZ-C-1(config)#router bgp 5000
BGP is already running; AS is 8234
RT-RM-TLD066-DMZ-C-1(config)#^Z
Index Process Name
0 connected
1 static
2 isis
3 bgp 8234
hope to help
Giuseppe
