1811 Default Chat Script Aborts Dial out
Oct 8th, 2008
I am configuring an 1811 with built in V.92 modem and I have matched the same settings I am using with a 1711 with a built in WIC modem, and the 1811 built in default chat script is aborting the dial out. How can I rectify this?
DEBUG DIALER
Oct 8 08:49:19 PDT: As1 DDR: rotor dialout [best] least recent failure is also most recent failure
*Oct 8 08:49:19 PDT: As1 DDR: rotor dialout [best] also has most recent failure
*Oct 8 08:49:19 PDT: As1 DDR: Dialing cause ip (s=10.137.1.2, d=10.41.1.4)
*Oct 8 08:49:19 PDT: As1 DDR: Attempting to dial 19057128464
*Oct 8 08:49:19 PDT: CHAT1: Attempting async line dialer script
*Oct 8 08:49:19 PDT: CHAT1: no matching chat script found for 19057128464
*Oct 8 08:49:19 PDT: CHAT1: Dialing using Modem script: d0efault-d0ials0cript & System script: none
*Oct 8 08:49:19 PDT: CHAT1: process started
*Oct 8 08:49:19 PDT: CHAT1: Asserting DTR
*Oct 8 08:49:19 PDT: CHAT1: Chat script d0efault-d0ials0cript started
*Oct 8 08:49:46 PDT: CHAT1: Found abort string BUSY expecting CONNECT
*Oct 8 08:49:46 PDT: CHAT1: Chat script d0efault-d0ials0cript finished, status = Connection aborted
*Oct 8 08:49:46 PDT: As1 DDR: disconnecting call
*Oct 8 08:50:01 PDT: As1 DDR: re-enable timeout
CONFIGURATION
interface Async1
bandwidth 38
ip unnumbered Loopback0
ip virtual-reassembly
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
dialer in-band
dialer pool-member 10
async mode interactive
compress stac
ppp authentication chap
interface Dialer10
bandwidth 38
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 10
dialer remote-name lclas5400a-on.ca
dialer string 19057128464
dialer-group 10
compress stac
line con 0
password 7 141B1107
login authentication MIS-Access
line 1
exec-timeout 0 0
modem InOut
transport preferred none
transport input all
transport output none
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
transport input all
autoselect during-login
autoselect ppp
line vty 0 4
password 7 020A0757
mchin345 Tue, 10/14/2008 - 08:51
No, This configuration will works fine.
Please verify you can able to dial the ISP and connect without using a external modem chat script.
If you want to see if the behavior changes, enable the following debugs:
Debug confmodem
Debug chat line 1
Debug ppp ne
Debug ppp authe
Debug dialer
Debug modem
And also recheck the configuration. It may help you.
For the configuration following guide may help you
http://www.cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/dialbkup.html#wp1029902
