Netgear FVS338 to Cisco Concentrator 3030
Oct 8th, 2008
I am the admin of the Cisco VPN Concentrator 3030, we have a customer that is trying to set up an L2L to our concentrator.
I have set up the L2L config unider Tunneling& security/IPSEC/Lan-to-Lan.
When the customer connects the Phase 1 passes as well as the Phase 2 But the Tunnel gets rejected because of the following:
Tunnel rejected: Policy not found for Src
What policy has to be set up?
Please Advise
Thank you
Overall Rating: 5 (1 ratings)
ajagadee Wed, 10/08/2008 - 12:41
  • Cisco Employee,
William,
"Tunnel rejected: Policy not found for Src:%s, Dst: %s!"
Cause: The concentrator was not able to find security policy information for the private networks/hosts indicated in the event. These networks or hosts were sent by the initiator and do not match any entries in the concentrator's IPSec rules. This is most likely a misconfiguration. Check the protected network configuration in the LAN to LAN screen on both sides and make sure that the local net on the initiator is the remote net on the responder and vice-versa. Pay special attention to wildcard masks, host addresses versus network addresses, etc.
Arul
** Please rate all helpful posts **
