Callmanager Service Stops
Oct 8th, 2008
CUCM 6.1 new installation, 4 node
Installation on HP DL380G5 machines
Everything appears ok, but the call manager service on each of the 4 machines stops after about 20 seconds. All other services running. If I start Call manager service it shows as started but then about 20 seconds later goes inactive.
I have only ever build CUCM on MCS machines and am wondering if there is a hardware problem. The machines were supplied by customer with 3GHz processors initially. CUCM would not install so customer changed the processors to 2.33GHZ and CUCM installed. Each node has 8Gb of memory
Rajesh Revuru Wed, 10/08/2008 - 09:47
  • Silver, 250 points or more
Check, if you have enough node licenses
ANDREW BERESFORD Wed, 10/08/2008 - 09:51
Thanks for the response, was one of my first checks.
CCM Node licence features says 7 units authorised and 4 units used
Rob Huffman Wed, 10/08/2008 - 09:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andrew,
This is symptomatic of the CCM 6.x "Feature License" missing. Everything will build properly but the Callmanager Service will not stay running. Have a look at this good post that has excellent tips from Java and Chris;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc0cd41
Hope this helps!
Rob
ANDREW BERESFORD Tue, 10/14/2008 - 06:01
Rob,
Many Thanks for the response. Just got a new licence key from Cisco and it all works.
Rob Huffman Tue, 10/14/2008 - 06:37
  • Hall of Fame,
    Founding Member
Hi Andrew,
Good work my friend! Glad to be of some assistance.
Cheers!
Rob
