LMS 3.1 Multiserver installation
Oct 8th, 2008
I have installed a LMS 3.1 in multiserver environment with ACS integration.
Primary server has got most of the modules installed where as Slave has got just CS and DFM modules.
The devices has been discovered and showing perfect on primary where as I can't see the devices in secondary box ( In DFM). The DCR is running fine in both of the server.
any thought ??
Joe Clarke Wed, 10/08/2008 - 10:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Are both servers integrated to the same ACS server? Are they both using the same System Identity User?
satishy_2 Wed, 10/08/2008 - 12:51
That's right.
They are using same ACS and same system identity user.
Joe Clarke Wed, 10/08/2008 - 12:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Check the Common Services homepage on the slave server to see if the devices are being synced from the master DCR. By default, DFM 3.1 does not automatically manage devices in DCR, so it may be a simple matter of going to DFM > Device Management > Device Import, and adding the devices from DCR.
satishy_2 Fri, 10/31/2008 - 08:58
I have tried to import the devices in DFM but it's not showing any devices there too.
Joe Clarke Fri, 10/31/2008 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Does this mean that the slave's Common Services homepage is not showing any devices as well?
satishy_2 Fri, 10/31/2008 - 10:03
common services on svale server is showing the devices. But on the DFM we can see those devices.
I have only 2 devices in DFM. If I got to import then it shows 0 devices.
Joe Clarke Fri, 10/31/2008 - 10:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't understand what you're seeing. Please post some screenshots illustrating the problem.
