Good Day,
Although fire codes vary from municipality to municipality, I'd like to present this question for general consideration/comment.
We are considering an installation of 1252(n)APs using poe. The plan is to use existing hard plenum cable that presently serves wired ports.
So while the cable and AP are both plenum rated, I'm wondering if anyone has encountered fire codes that regulate electrical transmission over unshielded twisted cable in confined space.
If you have done an installation and know that fire codes were not an issue I'd like to hear that as well (maybe even more).
Thank You
