Simple VLAN question
singhsaju Wed, 10/08/2008 - 11:56
You will need , "ip helper-address "
Directs the broadcast request as unicast to dhcp server.
For example:
interface Vlan112
ip address
ip helper-address
Pls rate helpful posts
Jon Marshall Wed, 10/08/2008 - 13:23
No need to apologize, that is what NetPro is for.
There are basically 2 ways to assign IP address to devices within a vlan
Note - usually there is a one-to-one relationship between a vlan and an IP subnet.
1) Assign them manually on each end device which is time consuming but for things like servers is generally what you do.
2) Assign them dynamically as Saju has covered in his post. You set up an IP subnet within a DHCP server and the DHCP server hands out IP addresses within the subnet to devices. Generally DHCP is used for client workstations/laptops.
franklinb Wed, 10/08/2008 - 20:26
Additionally, if you want to use PXE-boot with DHCP on those VLANs:
We needed to add another line since our PXE server has a different address:
int vlan x
ip address <>
ip helper-address
ip helper-address
ip directed-broadcast
access-list permit udp host any eq 402
ip forward-protocol udp 402
* 402 might be incorrect for other PXE implementations. This was for Altiris
