ASA 5510 vpn client?
Oct 8th, 2008
We are migrating from PIX to our ASA 5510's, what client(s) do I need to deploy to remote users? We currently use to connect to our vpn3000 concentrator, will that client work?
ajagadee Wed, 10/08/2008 - 12:32
Yes, client should work with the ASA5510. I would recommend that you test the ASA5510 and VPN Client in the lab with all the features that you were using on the VPN3000 before deploying it in production. That way, if something is not working its easy to troubleshoot then trying to troubleshoot in a live network.
** Please rate all helpful posts **
