ATM over PPP
Answered Question
Oct 8th, 2008
I have configured the below configuration in Cisco 1821 router
interface ATM0/0/0
description : ADSL Link to ISP
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35 ----------------- ( i got this information from ISP )
encapsulation aal5mux ppp dialer
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname fti/bt7u2aw
ppp chap password 0 hp6q64c
ppp pap sent-username fti/bt7u2aw password 0 hp6q64c
end
But the internet link is not coming up
ATM0/0/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
Description: : ADSL Link to ISP
MTU 4470 bytes, sub MTU 4470, BW 320 Kbit, DLY 1600 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:36:00, output hang never
Last clearing of "show interface" counters 00:20:29
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
There is no packet in and Out
please any one help ,me
Correct Answer by Giuseppe Larosa about 8 years 6 months ago
Hello Thiru,
it is an authentication issue not an encapsulation problem, they probably have auto-sense for detecting PPPoA and PPPoEoA.
Contact your provider support team for checking authentication data you have to use
Hope to help
Giuseppe
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Wed, 10/08/2008 - 12:41
  • Hall of Fame,
    Founding Member
Hello Thiru,
your config is actually a PPPoE over ATM and not PPP over ATM
to troubleshoot
terminal monitor
debug ppp negotiation
debug ppp authentication
int atm0/0/0
shut
no shut
collect the output and post it
PPP over ATM example:
interface ATM0/0
no ip address
no ip mroute-cache
pvc 8/35
dialer pool-member 2
interface Dialer2
ip mtu 1492
encapsulation ppp
dialer pool 2
dialer-group 1
no cdp enable
end
Hope to help
Giuseppe
thiru.vel10 Wed, 10/08/2008 - 12:52
Oct 8 20:41:38.910: Vi3 LCP: Timeout: State Listen
Oct 8 20:41:38.910: Vi3 PPP: No remote authentication for call-out
Oct 8 20:41:38.910: Vi3 LCP: O CONFREQ [Listen] id 62 len 10
Oct 8 20:41:38.910: Vi3 LCP: MagicNumber 0x1ECC4D32 (0x05061ECC4D32)
Oct 8 20:41:40.926: Vi3 LCP: Timeout: State REQsent
Oct 8 20:41:40.926: Vi3 LCP: O CONFREQ [REQsent] id 63 len 10
Oct 8 20:41:40.926: Vi3 LCP: MagicNumber 0x1ECC4D32 (0x05061ECC4D32)
Oct 8 20:42:29.086: Vi3 PPP: Authorization required
Oct 8 20:42:29.086: Vi3 PPP: No remote authentication for call-out
Oct 8 20:42:31.130: Vi3 PPP: No authorization without authentication
Oct 8 20:42:31.134: Vi3 CHAP: I CHALLENGE id 253 len 29 from "BSLYO153"
Oct 8 20:42:31.134: Vi3 CHAP: Using hostname from interface CHAP
Oct 8 20:42:31.134: Vi3 CHAP: Using password from interface CHAP
Oct 8 20:42:31.134: Vi3 CHAP: O RESPONSE id 253 len 32 from "fti/bt7u2aw"
Oct 8 20:42:31.342: Vi3 CHAP: I FAILURE id 253 len 21 msg is "permission denie
Oct 8 20:42:35.358: Vi3 PPP: Authorization required
Oct 8 20:42:35.358: Vi3 PPP: No remote authentication for call-out
Oct 8 20:43:25.534: Vi3 PPP: Authorization required
Oct 8 20:43:25.534: Vi3 PPP: No remote authentication for call-out
Oct 8 20:44:15.710: Vi3 PPP: Authorization required
Oct 8 20:44:15.710: Vi3 PPP: No remote authentication for call-out
Giuseppe Larosa Wed, 10/08/2008 - 13:02
  • Hall of Fame,
    Founding Member
Hello Thiru,
from your output we can see that PPP negotiation fails during authentication
the remote router "BSLYO153" sends a CHAP challenge
your router answers
but the answer is not liked by remote
contact your provider and check authentication data
However, ATM encapsulation is correct
Hope to help
Giuseppe
thiru.vel10 Wed, 10/08/2008 - 13:02
HI Thanks for you response , I have configured the same which you gave . but still i am having the same problem.
Out put
*Oct 8 21:08:08.894: Vi3 LCP: Timeout: State ACKsent
*Oct 8 21:08:08.894: Vi3 LCP: O CONFREQ [ACKsent] id 42 len 10
*Oct 8 21:08:08.894: Vi3 LCP: MagicNumber 0x1EE488F4 (0x05061EE488F4)
*Oct 8 21:08:08.926: Vi3 LCP: I CONFACK [ACKsent] id 42 len 10
*Oct 8 21:08:08.926: Vi3 LCP: MagicNumber 0x1EE488F4 (0x05061EE488F4)
*Oct 8 21:08:08.926: Vi3 LCP: State is Open
*Oct 8 21:08:08.926: Vi3 PPP: No authorization without authentication
*Oct 8 21:08:08.926: Vi3 PPP: Phase is AUTHENTICATING, by the peer
*Oct 8 21:08:08.926: Vi3 CHAP: I CHALLENGE id 184 len 29 from "BSLYO153"
*Oct 8 21:08:08.930: Vi3 CHAP: Using hostname from interface CHAP
*Oct 8 21:08:08.930: Vi3 CHAP: Using password from interface CHAP
*Oct 8 21:08:08.930: Vi3 CHAP: O RESPONSE id 184 len 32 from "fti/bt7u2aw"
*Oct 8 21:08:12.942: Vi3 CHAP: I CHALLENGE id 185 len 29 from "BSLYO153"
*Oct 8 21:08:12.942: Vi3 CHAP: Using hostname from interface CHAP
*Oct 8 21:08:12.942: Vi3 CHAP: Using password from interface CHAP
*Oct 8 21:08:12.942: Vi3 CHAP: O RESPONSE id 185 len 32 from "fti/bt7u2aw"
*Oct 8 21:08:17.046: Vi3 CHAP: I CHALLENGE id 186 len 29 from "BSLYO153"
*Oct 8 21:08:17.050: Vi3 CHAP: Using hostname from interface CHAP
*Oct 8 21:08:17.050: Vi3 CHAP: Using password from interface CHAP
*Oct 8 21:08:17.050: Vi3 CHAP: O RESPONSE id 186 len 32 from "fti/bt7u2aw"
*Oct 8 21:08:17.206: Vi3 CHAP: I FAILURE id 186 len 21 msg is "permission deni
d"
*Oct 8 21:08:17.210: Vi3 LCP: I TERMREQ [Open] id 86 len 4
*Oct 8 21:08:17.210: Vi3 LCP: O TERMACK [Open] id 86 len 4
*Oct 8 21:08:17.210: Vi3 PPP: Sending Acct Event[Down] id[2EE]
*Oct 8 21:08:17.210: Vi3 PPP: Phase is TERMINATING
*Oct 8 21:08:19.198: Vi3 LCP: Timeout: State TERMsent
*Oct 8 21:08:19.198: Vi3 LCP: State is Closed
*Oct 8 21:08:19.198: Vi3 PPP: Phase is DOWN
*Oct 8 21:08:19.198: Vi3 PPP: Phase is ESTABLISHING, Passive Open
*Oct 8 21:08:19.198: Vi3 LCP: State is Listen
*Oct 8 21:08:21.214: Vi3 LCP: Timeout: State Listen
*Oct 8 21:08:21.214: Vi3 PPP: Authorization required
*Oct 8 21:08:21.214: Vi3 PPP: No remote authentication for call-out
*Oct 8 21:08:21.214: Vi3 LCP: O CONFREQ [Listen] id 43 len 10
*Oct 8 21:08:21.214: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:23.230: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:23.230: Vi3 LCP: O CONFREQ [REQsent] id 44 len 10
*Oct 8 21:08:23.230: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:25.246: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:25.246: Vi3 LCP: O CONFREQ [REQsent] id 45 len 10
*Oct 8 21:08:25.246: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:27.262: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:27.262: Vi3 LCP: O CONFREQ [REQsent] id 46 len 10
*Oct 8 21:08:27.262: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:29.278: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:29.278: Vi3 LCP: O CONFREQ [REQsent] id 47 len 10
*Oct 8 21:08:29.278: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:31.294: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:31.294: Vi3 LCP: O CONFREQ [REQsent] id 48 len 10
*Oct 8 21:08:31.294: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:33.310: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:33.310: Vi3 LCP: O CONFREQ [REQsent] id 49 len 10
*Oct 8 21:08:33.310: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:35.326: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:35.326: Vi3 LCP: O CONFREQ [REQsent] id 50 len 10
*Oct 8 21:08:35.326: Vi3 LCP: MagicNumber 0x1EE4C0F6 (0x05061EE4C0F6)
*Oct 8 21:08:37.342: Vi3 LCP: Timeout: State REQsent
*Oct 8 21:08:37.342: Vi3 LCP: O CONFREQ [REQsent] id 51 len 10
Correct Answer
Giuseppe Larosa Wed, 10/08/2008 - 13:09
  • Hall of Fame,
    Founding Member
Hello Thiru,
Hope to help
Giuseppe
thiru.vel10 Thu, 10/09/2008 - 10:14
Hi.
I request the ISP to reset the our Account password and then I have configured the same in dialer interface now the internet is up and running fine . thanks a lot
