ICMP from certain Networks
jstabl
Hello all. I have the following requirements:
Internal network includes
10.1.1.x/24
10.1.2.x/24
10.1.3.x/24
10.1.4.x/24
I want to allow only the 10.1.1.x network to do ICMP ping and traceroute to the outside networks such as yahoo etc..
Here is part of my config
object-group icmp-type icmp-outside-in
icmp-object echo-reply
icmp-object time-exceeded
icmp-object unreachable
access-list outside_access_in extended deny ip 0.0.0.0 255.0.0.0 any
access-list outside_access_in extended deny ip 10.0.0.0 255.0.0.0 any
access-list outside_access_in extended deny ip 127.0.0.0 255.0.0.0 any
access-list outside_access_in extended deny ip 172.16.0.0 255.240.0.0 any
access-list outside_access_in extended deny ip 192.168.0.0 255.255.0.0 any
access-list outside_access_in extended deny ip 224.0.0.0 224.0.0.0 any
access-list outside_access_in extended deny ip host FTP_Block any
access-list outside_access_in extended permit tcp any host xx.xx.157.198 object-group Notes
access-list outside_access_in extended permit tcp any host xx.xx.157.199 eq smtp
access-list outside_access_in extended permit tcp any host xx.xx.157.200 object-group FTP
access-list outside_access_in extended permit icmp any host xx.xx.157.200
access-list outside_access_in extended permit tcp any object-group Production_Websites_ref object-group Web
access-list outside_access_in extended permit tcp any host xx.xx.157.217 eq ssh
access-list outside_access_in extended permit tcp any host xx.xx.157.216 object-group Notes
access-list outside_access_in extended permit icmp any xx.xx.157.192 255.255.255.224 object-group icmp-outside-in
access-list outside_access_in extended deny icmp any xx.xx.157.192 255.255.255.224
access-list outside_access_in extended deny ip any any
access-list dmz_access_in extended permit tcp 10.1.4.0 255.255.255.0 host 10.1.4.21
access-list dmz_access_in extended permit udp 10.1.4.0 255.255.255.0 host 10.1.4.21 eq domain
access-list dmz_access_in extended permit tcp 10.1.4.0 255.255.255.0 host 10.1.4.25
access-list dmz_access_in extended permit udp 10.1.4.0 255.255.255.0 host 10.1.4.25 eq domain
access-list dmz_access_in extended permit ip 10.1.4.0 255.255.255.0 any
access-list dmz_access_in extended permit tcp any host 10.1.4.24
access-list dmz_access_in extended permit udp any host 10.1.4.24
access-list dmz_access_in extended permit icmp any host 10.1.4.24
access-list dmz_access_in extended permit ip 10.1.4.0 255.255.255.0 host 10.1.4.32
access-list dmz_access_in extended permit tcp any host 10.1.4.26 object-group Notes
access-list dmz_access_in extended permit icmp 10.1.4.0 255.255.255.0 host 10.1.4.31
access-list dmz_access_in extended permit tcp any host 10.1.4.25 eq ldap
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit udp any any
access-list inside_access_in extended permit tcp any any
Marwan ALshawi
what i suggest u is to have a look at the following link which will be helpful for ur case:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
good luck
if helpful Rate
Marwan ALshawi
good luck
if helpful Rate
Thank you. I added this ACE and i can ping out from all internal networks.
So I think if I want to block other networks accept 10.1.1.0/24 I need another ACE on the inside.
Right now I have this on the inside.
think it needs to change to
access-list inside_access_in extended permit icmp 10.1.1.0 255.255.255.0 any
the last one will allow icmp as stated in the ACL and deny anythig else !!!
please, rate the helpful post
