SRST across 2 gateways
Answered Question
Oct 8th, 2008
Does anyone have any experience or documentation regarding the process of splitting SRST duties between 2 same site routers? I have a customer with a remote location and they would like to have SRST at this location - 800+ employees. I have heard there is a method by which you can split the SRST registrations between 2 gateways in order to surpass the 730 ephone limitation of one gateway.
Correct Answer by Marwan ALshawi about 8 years 4 months ago
ok the trick here is to put lets say half users in one device pool and others in other device pool then,creat two srst deffenetions
then fo each device pool assigne one of the gateways as the SRST router regarding its the router or gateway IP address
which should be the same as the ip address set with ip source add x.x.x.x under the srst config
simple :)
good luck
if helpful Rate
Overall Rating: 4 (2 ratings)
Correct Answer
Marwan ALshawi Wed, 10/08/2008 - 17:35
simple :)
good luck
if helpful Rate
gbwatkins Wed, 10/08/2008 - 17:36
Thank you. I was planning on doing that however someone told me this was now a feature function of IOS - guess I was misinformed.
Cheers!
