dialup with slip problem, please help me
Oct 8th, 2008
Hi All,
My diagarm
PSTN
PC( with modem ) --------> Router 2811( with NM8-AM-Module ) | LAN
I has creat a connection when dialup with slip but I do not registing on my network becase Router don't assigned IP.
Please help me how to configure aaa authorization network on Router.
aaa authentication login default local
aaa authentication ppp default local none
aaa authorization network default local none
interface Loopback0
ip address 192.168.15.1 255.255.255.0
interface Group-Async1
description $FW_OUTSIDE$
ip unnumbered Loopback0
encapsulotion slip
ip nat inside
ip nat enable
ip virtual-reassembly
ip tcp header-compression passive
async mode interactive
peer default ip address pool DIALIN
group-range 1/0 1/7
routing dynamic
ip local pool DIALIN 192.168.15.60 192.168.15.70
line 1/0 1/7
login authentication
modem InOut
modem autoconfigure type micro_usa
transport input all
autoselect during-login
autoselect slip
stopbits 1
Please end eemail to: [email protected].
Thanks and best regard
amritpatek Tue, 10/14/2008 - 09:47
If asynchronous dynamic routing is enabled, you can enable routing at the user level by using the routing keyword with the slip or ppp EXEC command.
To enable IP-SLIP on a synchronous or asynchronous interface, use the following commands in interface configuration mode:
Step 1 : Router(config-if)# ip address ip-address mask or
Router(config-if)# ip unnumbered type number
Step 2 : Router(config-if)#encapsulation slip
Step 3 : Router(config-if)# async mode interactive
For the AAA authentication following URL help you :
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfathen.html#wp1000971
