Simple Outbound Call
Oct 8th, 2008
We are evaluating CCM 6.0.1. We want to test an outbound call. Here's the setup. We have a 2651XM router with VWIC-1MFT-E1 configured as ISDN-PRI for voice. This gateway is already registered to the CCM. The ISDN-PRI is connected to Avaya PBX and they said they are ready to accept calls from us going to outside lines.
Now, what are the steps I needed to do in the Cisco Call Manager Console? I really don't know what to do. Thanks.
John
Overall Rating: 4 (2 ratings)
Md. Mijanur Rahman Thu, 10/09/2008 - 00:18
  • Bronze, 100 points or more
It's simple.
If it's the H.323 Gateway, at CUCM,
1. Go to Route/Hunt>Route Pattern
2. In the 'Route Pattern' match your numbering plan you are dialing (if you are dialing the numbering plan from 123456 to 123789, then put there 123XXX#, or 1!#
3. In the Numbering Plan, select the correct one (hopefully NANP),
4. Select the Gateway you have already added as H.323 gateway.
In the gateway make a pots dial peer:
#conf t
(config)# dial-peer voice 1234 pots
(config)# description **** Outbound ****
(config)# destination-pattern 123...
(config)# no digit-strip
(config)# port
(config)# forward-digits all
Hope this will work if it's the H.323 gateway, is it H.323 or MGCP?
John Patrick Lopez Thu, 10/09/2008 - 02:45
Thank you so much for your reply. I am using MGCP I will post my current configuration and please help check if I did something wrong or something not really important.
PHMNLGTW001#sh running-config
Building configuration...
Current configuration : 6466 bytes
! Last configuration change at 07:57:03 GMT Thu Oct 9 2008 by john.lopez
! NVRAM config last updated at 16:56:32 GMT Wed Oct 8 2008
version 12.4
service password-encryption
hostname PHMNLGTW001
boot-start-marker
boot system flash:c2600-a3jk9s-mz.123-11.T10.bin
boot system flash:c2600-js2-mz.123-8.T11.bin
boot system flash:c2600-advipservicesk9-mz.123-22a.bin
boot system flash:c2600-advipservicesk9-mz.124-12.bin
boot-end-marker
logging buffered 20000 debugging
aaa new-model
aaa session-id common
clock timezone GMT 0
network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip cef
no ip domain lookup
ip host CCM-demo 10.199.32.106
isdn switch-type primary-net5
isdn logging
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-30 service mgcp
interface FastEthernet0/0
ip address 10.199.1.80 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.199.1.1
ip http server
ip http authentication local
no ip http secure-server
control-plane
voice-port 1/0:15
no echo-cancel enable
cptone PH
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config dialpeer-prefix 200
mgcp
mgcp call-agent CCM-demo 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
ntp clock-period 17208371
ntp server 10.199.32.2
ntp server 10.199.32.3
end
PHMNLGTW001#
Marwan ALshawi Thu, 10/09/2008 - 03:27
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
use the links bellow helpful for u :
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
the following one helpful to understand how to make route pattrens
MGCP with Digital CAS and Cisco CallManager Configuration Example
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a008022eaa3.shtml
good luck
if helpful Rate
John Patrick Lopez Thu, 10/09/2008 - 06:19
Thank you so much. It helped a lot. We were able to make it work by tweaking Route Pattern. Thanks guys. =)
