HELP! Weird Problem With PIX 501
Answered Question
Oct 9th, 2008
Attached is the network diagram and Pix Configuration. We have data circuits for all our branches just installed. The problem is that the Pix just stops to ping the branch Office routers.
1. From the Pix can ping 192.168.1.2 & 1.3
2. From 192.168.1.2 & 1.3 can ping all the networks.
3. From the Pix cannot reach the branch routers.
Appreciate all your support.
Sarfaraz
Correct Answer by Marwan ALshawi about 8 years 6 months ago
the idea as follow
u have the static route configured corectly on ur PIX
on the ISP router u need static route point to each barnch offic network thorugh the isp ip u have
and u need a static route like
try the following line to the ISP router and try then try to pin
ip route 192.168.1.0 255.255.255.0 192.168.1.254
for returne traffic or traffic comeing from branch to ISP going to PIX
in ur ISP i have seen u done like
ip route 192.168.0.0 255.255.0.0 10.x.x.x
this include 192.168.1.0/25 so the traffic when wanna go to the PIX network will go back to the ISP and this is the problem u have
try to fix it based on the above directions
good luck
Overall Rating: 5 (1 ratings)
Marwan ALshawi Thu, 10/09/2008 - 00:52
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
do the branch routers have route to the pix configured correctly ?
Marwan ALshawi Thu, 10/09/2008 - 01:34
i can see the problem is routing issue
one more question the ISP routers belong to u ? i mean u have its config ?
can u tell me the IP address of directly conected interfaces of ISP1 and the brach router u sent me to give u the right config
sarfarazkazi Thu, 10/09/2008 - 01:38
Dear Marwan,
Attached is the configuration of the HO router(isp1.txt) and the branch router (apbbr.txt)
Sarfaraz
Marwan ALshawi Thu, 10/09/2008 - 01:49
ok
in ur diagram there is somthing missing
what are these IPs
10.250.3.1
10.250.17.2
can u tell me what connectivity between the ISP rote and the brantch routers and do u have the connection direcrctly from pix to ISP?
and on ur pix i see u have the interface with ip 192.168.1.254
and u have other interface on the pis has ip in the same subnet !!!!
sorry but i want to be aware about the network
sarfarazkazi Thu, 10/09/2008 - 01:55
The IPs are of the ISPs. My LAN range is (192.168.1.0/254) I am not well versed with Pix. This is how it is.. I am using these IPs from the range to route the branch subnets. It was working and then it stopped.
Pix IP- 192.168.1.254
ISP-1 router IP: 192.168.1.2
ISP-2 router IP: 192.168.1.3
I have attached the configuration of pix as well.
Marwan ALshawi Thu, 10/09/2008 - 02:02
please
what these IPs represent
10.250.17.1
10.250.3.1
sarfarazkazi Thu, 10/09/2008 - 02:04
these IPs belong to the ISP backbone. They are /30 subnets for routing in their internal network. I have nothing to do their network.
Marwan ALshawi Thu, 10/09/2008 - 02:05
please
10.250.17.1
10.250.3.1
sarfarazkazi Thu, 10/09/2008 - 02:27
I have already mentioned that the router belongs to ISP they are the ones who are routing it.
Marwan ALshawi Thu, 10/09/2008 - 02:33
try to add the following line on ISP route
and let me know
sarfarazkazi Thu, 10/09/2008 - 02:50
No it doesnt work. From pix (1.254) i can ping (1.2). From (1.2) I can ping 2.1,3.1,4.1. But from the Pix I cannot ping 2.1,3.1 & 4.1
Correct Answer
Marwan ALshawi Thu, 10/09/2008 - 03:08
the idea as follow
good luck
sarfarazkazi Thu, 10/09/2008 - 03:20
yeah got it working now...thank u so much for your time and efforts..
Sarfaraz
Marwan ALshawi Thu, 10/09/2008 - 03:24
i am glad its working now
was the static line the problem right ?
