PIX 501 & Branch Office
Oct 9th, 2008
Attached is the network diagram and Pix Configuration. We have data circuits for all our branches just installed. The problem is that the Pix just stops to ping the branch Office routers.
1. From the Pix can ping 192.168.1.2 & 1.3
2. From 192.168.1.2 & 1.3 can ping all the networks.
3. From the Pix cannot reach the branch routers.
Appreciate all your support.
Sarfaraz
singhsaju Fri, 10/10/2008 - 06:56
Hi Sarfaraz,
Add following command to the PIX and then check and post results:
icmp permit any inside
Saju
pls rate helpful posts
John Blakley Fri, 10/10/2008 - 10:34
What side of the branch routers can you not reach? If you source your ping on the pix, does it work? (ping outside 192.168.x.x)
Do a debug icmp trace (I think), and it will show you where you're losing your packets.
John
