c3400 Low on memory; try again later
Oct 9th, 2008
On a ME340x Software (ME340x-METROIPACCESSK9-M), Version 12.2(44)SE, RELEASE SOFTWARE (fc1) with less then a 1G traffic summary on all ports a have that problem when atach to console ( telnet and ssh didn`t work )
%% Low on memory; try again later
on it i have ospf with less then 100 routes ( in area 0 ) and qinq at the one gig interface . Evrything is working l2 and l3 but i dont have any access to the device ....
Overall Rating: 2 (1 ratings)
guruprasadr Thu, 10/09/2008 - 01:00
  • Gold, 750 points or more
HI, [Pls RATE if HELPS]
Depending on *what* is eating the memory, you might be able to free enough to get in by shutting down all dynamic routing from the router's neighbours (like "BGP neighbours shutdown", OSPF interface passive, etc.)
If it's just a bug and there is no free memory / no large enough chunk left, then you'll need to reboot...
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Eli Barb Fri, 12/05/2008 - 13:24
It doesn't help for your current situation, but we've seen memory get eaten up by PXE boot hosts continually rebooting and trying to reach a PXE boot server.
