10-09-2008 12:43 AM - edited 03-15-2019 01:50 PM
Hi ,
I am using CCM version 6 .x .I am using MiniCoreSFTP software
I am taking the backup of CCM through DRS. After the backup is completed, I am getting the error message as SFTP failure,not enough disk space .BackUP completed.
But when I check the disk space on PC where SFTP is running , lot of space is avaialble in Hard Disk. Also, with same PC & SFTP software , I am able to take the backup of other clusters.
The Backup file which is created is a tar file.
what I understand is that after the backup is completed , it is copied onto CCM Hard disk . From there it is moved to PC Hard disk. Is it so?Pls. confirm
regds,
aman
Solved! Go to Solution.
10-18-2008 07:19 AM
try freeftpd, it's the one we recommend
java
if this helps, please rate
10-15-2008 01:01 PM
Regarding the issue first try to run the Disaster recovery locally, if it is working locally then there might be a permission issue with the folder in which you are going to transfer. Also try to use a different folder and point to it and then try.
10-15-2008 05:12 PM
i will try & get back to you.
regds,
aman
10-17-2008 06:48 PM
I tried on a different PC but this time the problem is different that is it is copying only few files i.e. one subscriber /TFTP server and leaving PUB / other subscribers in th e same cluster . Even touhgh , while taking backup , it shows 100% in DRS .
I think there is a problem with this SFTP software for taking backup when data volume is more since the same fotware is working fine when no. of servers are less.
I would download another sftp software , try & let u know.
regds,
aman
10-18-2008 07:19 AM
java
10-20-2008 05:15 PM
Hi Java,
thanks for the help. I downloaded FreeFTPd software & it worked.
regds,
aman
