RME 3.5
Oct 9th, 2008
1) Can RME 3.5 have more then one database ID?
2) How do we create database ID in RME 3.5? How does it tied with SQL?
3) How do we connect CiscoWorks with another application which have CiscoWorks adapter to pull information (e.g. device configuration) from CiscoWorks?
Joe Clarke Thu, 10/09/2008 - 07:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
First, RME 3.5 is end of support. You should upgrade to LMS 2.6 or higher which includes RME 4.x.
I don't understand your first two questions. There is only one RME database, and it has a unique name and engine ID.
In general, direct connection to the RME database is not supported from third party applications. To what adapter do you refer?
