1801w ISR and ADSL2
Oct 9th, 2008
I am having an issue with an 1801 connected to an Eircom ADSL2 line. Everything works for a while, the ADSL connectes via PPPoE and the IPSec site-to-site I configured connects. Then the connection drops for about 2 minutes before reconnecting witout intervention. It is not a problem with the ADSL line as it was up constantly on the Eircom provided ADSL router...
Has anybody had any similiar issues with ISRs?
Anything specific I should be looking at?
Config below
Colin
!version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no logging monitor
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.9.0.1 10.9.1.2
ip dhcp excluded-address 10.9.1.104 10.9.255.254
ip dhcp pool dublinlan
import all
network 10.9.0.0 255.255.0.0
domain-name mydomainname.com
dns-server 10.10.1.253 10.10.1.254
netbios-name-server 10.10.1.253
default-router 10.9.1.1
lease 8 1
ip name-server *.*.*.*
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username ********* privilege 15 password 0 ***********
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key
address *.*.*.*
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to*.*.*.*
set peer *.*.*.*
set transform-set ESP-3DES-SHA
match address 100
archive
log config
hidekeys
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Dot11Radio0
no ip address
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Vlan1
ip address 10.9.1.1 255.255.0.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ********
ppp chap password 0 ********
ppp multilink
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.9.0.0 0.0.255.255
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.9.0.0 0.0.255.255 10.10.0.0 0.0.255.255
access-list 101 remark SDM_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny ip 10.9.0.0 0.0.255.255 10.10.0.0 0.0.255.255
access-list 101 permit ip 10.9.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
line con 0
line aux 0
line vty 0 4
login
end
